User Interface, output panel
Dmitry D. shared this idea 8 years ago
Completed
Hello!
It will be useful after the shortcut pressed View: Maximize|Restore Output panel (Ctrl+9)
the Output panel will receive focus and user can continue to work with keyboard.
Replies (6)
2
We plan to resolve the issue in the next update.
Maybe this will help, You can use "command+shift+enter" to execute the entire/selected script and expand the whole result tree immediately or use "Shift+ESC" to set focus to tree view/table view.
Hello!
The problem is still there ☹.
When I work with maximized Output panel I should to press every time "Shift+ESC" to set focus to the table view.
I would be grateful if you would fix this problem.
Which NoSQLBooster build are you using, 4.x or 5.x? And, Windows, MacOS or Ubuntu?
Windows 10
I tried "CTRL+9" to maximized Output panel with 5.0.3. It will set focus to the table view and works well. Maybe my steps are different from yours.
Could you please provide the following information?
  1. Steps to Reproduce: Minimized, easy-to-follow steps that will trigger the described problem. Include any special setup steps.
  2. Actual Results: What the application did after performing the above steps.
  3. Expected Results: What the application should have done if there was no bug.
I am sorry, it must be in the another topic http://feedback.nosqlbooster.com/topic/shortcut-for-save-changes-in-edit-field-valuetype-dialog
I will not duplicate, write here.
Work with documents in the Output panel.
1. Select field
2. run Edit field command, save.
3. Output panel loses focus.
4. Press «Shift+ESC» to return focus.
