Connecting to Mongo through a Jumpserver
Pamen Gill shared this idea 10 years ago
Under Consideration
I am trying to create a connection in MongoBooster to my MongoDB however to access the DB the connection must first route through a jump server. I am having difficulties configuring MongoBooster to connect in such a way.
If I connect to the mongoDB via PuTTY (or similar) then I can input a remote command under SSH so that the connection first routes to the jump server and then immediately runs the remote command to connect to the mongo server. Is this possible in MongoBooster?
Thanks
Replies (1)
Hi Pamen,
We need a more detailed scenario to create a test environment, could you provide it and give us the reproduction steps? Thank you.
