Preserve formatting when copy code from script editor
Sergey Berezovskiy shared this idea 8 years ago
Completed
When I copy this query from MongoBooster script editor
db.Farms.aggregate([
    {$project: {_id: 1, Name:1, FarmerId:1 }},
    {$lookup:{
        localField: "_id",
        foreignField: "FarmId",
        as: "Orders"
    {$match: {Orders:[]}},
    {$group:{_id: "$FarmerId", count: {$sum:1}, names:{$push:"$Name"}, Farms: {$push:"$_id"}}},
    {$lookup: {
         localField: "_id",
         foreignField: "_id",
         as: "Farmer"
    {$unwind: "$Farmer" },
    {$addFields: {
            FarmerName: "$Farmer.Name"
        $project: {
            Provider: 0
and paste it somewhere (e.g. Skype or Notepad) I get a code without line breaks
db.Farms.aggregate([    {$project: {_id: 1, Name:1, FarmerId:1 }},    {$lookup:{        from: "Orders",        localField: "_id",        foreignField: "FarmId",        as: "Orders"    }},    {$match: {Orders:[]}},    {$group:{_id: "$FarmerId", count: {$sum:1}, names:{$push:"$Name"}, Farms: {$push:"$_id"}}},    {$lookup: {         from: "Farmers",         localField: "_id",         foreignField: "_id",         as: "Farmer"      }    },    {$unwind: "$Farmer" },    {$addFields: {            FarmerName: "$Farmer.Name"        }    },    {        $project: {            Provider: 0        }    }    ])
Other tools like Robomongo preserve script formatting - that is very handy feature when you share scripts with other people.
Replies (4)
MongoBooster uses Unix line-endings, but Notepad only recognises CR, LF (0x0d, 0x0a) windows-style line-ending.
If your aversion to notepad++/sublime text and other text editors is that they are not a standard part of all Windows systems, use Wordpad. It's not quite as rudimentary as Notepad.
Wordpad will correctly read and display text files with with Unix line-endings.
If I install Windows application, as a user, I don't expect it will follow Unix conventions or iOS conventions. I expect it will follow Windows conventions (as RoboMongo and MongoChief do).
Correct way is to use environment-specific line endings. E.g. in .NET there is a `Environment.NewLine` value which holds appropriate line ending value.
I got it. I have added the issue to our to-do list. We will resolve the issue in the next update.
resolved in 4.1.3
