Wrong port?
Andreas Brunsmann shared this problem 7 years ago
Cannot Reproduce
I got problems connecting to a local mongo db instance after the succesfull login via ssh. The details show that a different port ist used than defined in the settings.
884a2ef746812150feef99eea2eb44ab
If i click on "To URI" i can use the generated string on the shell without any problems to log the user in. In this string the port is right. What am i doing wrong. Same settings work in Robo 3T too.
87ec5cee42c272c88ec49e4f76a5f9e0
Replies (5)
Only from the error description, I can not locate the problem, can you give me a complete reproduction step.
I set my credentials for SSH (private key file, passphrase, user) and than inserted my credentials in the "Authentication" tab. In the "Basic" tab it says 27017 for port. When i hit "To URI" it uses this port. When i hit "test connection" it seems to use another random generated (?) port.
92c4bb106f07c5e4bdbb4c742b698f5a
12bd4bb823f27b60039c5259294c2941
UPDATE: I created another entry in the connections list without a "mark with color" setting and name is still "localhost". That one works:
943d592f9b392ede9cbbbe85dc344847
Thanks.
I tried to create an SSH connection that was the same as your configuration, the same name "IFU2 | BDB", the same " Mark with Color ", but still can't reproduce the problem
I just exported my connections and send it to you by mail. By checking the json file i noticed that i referenced a public key file not PKK in the first connection ;-)
That explains why it wont work - but why does the test connection-funcion mark this as OK?
Anyway - thx for your help!
I have the same issue at the moment with V6.
What you you mean with ... you referenced a pub-key instead a PKK?
So at least your issue was that the ssh-connection was not established in the right way?
