subCollection.getCollection is not a function...
Scott Colestock shared this problem 9 years ago
Solved
Sometimes when I double click on a collection to do a simple find, I'm getting the error below. Any suggestions? this is against a mongo 2.6 cluster.
"message" : "subCollection.getCollection is not a function",
"stack" : "TypeError: subCollection.getCollection is not a function" +
"at evalmachine.<anonymous>:5770:51" +
"at Array.forEach (native)" +
"at DB._defineCollection (evalmachine.<anonymous>:5768:35)" +
"at evalmachine.<anonymous>:1:4" +
"at ContextifyScript.Script.runInContext (vm.js:35:29)" +
"at Object.exports.runInContext (vm.js:67:17)" +
"at /Applications/mongobooster.app/Contents/Resources/app.asar/backend/mongoHandler.js:547:23" +
"at tryBlock (/Applications/mongobooster.app/Contents/Resources/app.asar/node_modules/asyncawait/src/async/fiberManager.js:39:33)" +
"at runInFiber (/Applications/mongobooster.app/Contents/Resources/app.asar/node_modules/asyncawait/src/async/fiberManager.js:26:9)"
Replies (7)
Could you please give me the complete code to recall the issue?
And, getCollection is a db method, not a collection method.
e.g.
db.getCollection("user").find()
I was literally just double-clicking on a collection (which generated . "db.getCollection("groupride.group.audit").find({})" ) and received the error above - I wasn't attempting to write any code myself when getting the error above.
Any update on this? Does it matter that the collection has periods in the name, such as:
db.getCollection("a.b.c").find({})
It works well with the latest build v3.5.6.
3c1f018d96567ddd10755a2139af531f
I am on the latest version and still experiencing this issue - see below.67c40c47285a3fba7711cc021fc23919
Thank you for your feedback. I can recall it locally.
I have worked out a new build to resolve the issue, please download and give it a try.
http://s3.mongobooster.com/download/3.5/mongobooster-3.5.7.dmg
Excellent - that works - thank you.
