Remove atrributes on documents. Problem!
Dario Cammarano shared this question 7 years ago
Answered
When i edit a document to remove some attributes.
I get "WriteResult({ "nMatched" : 1, "nUpserted" : 0, "nModified" : 0 })"
Doesn't modify the document.
This is not really a NoSQLBooster bug, and the script returns the response result of the Mongo server. It's the same result as your execution in Mongo Shell.
/9c8205f5d5a206717371dcaa2e134266
And, If you want to remove "lastName" field, you should use $unset operator:
db.xxxx.update({_id:"xxxx"}, {$unset: {lastName:1}})
Replies (1)
Do you mean to return the wrong prompt or failed to modify it? If you're reporting a /1f41e bug, please make sure you include steps to reproduce it.
  • NoSQLBooster Version
  • Operating System (Windows/Mac/Ubuntu):
  • Expected Behavior
  • Actual Behavior
  • How to Reproduce
  • Screenshots
Hi Qinghai.
NoSQLBooster v5.1.8
Operating System. Windows
For example i have a document.
/4593f6b5f30ca00e3c4fdc6066db88c1
And i remove the lastName.
/88458340bd677a33c1056a57bc3e52cf
When i execute the query. with ctrl + enter. I get
/cca8138817bc04c2f20f7f9bee7a4bd8
It happens always when i want only erease content from the document, and with all documents.
Thanks!!
2
Thanks for the Feedback!!!
