It is not possible to copy raw string value from the document field.
Yaroslav Kihtan shared this problem 8 years ago
Solved
Hello, we have text lines stored in one of the document field.
"fieldName": "line 1\r\nline 2\r\n..."
A lot of them.
I did not found a way neither to view nor copy such values as a raw string - NOT a json-encoded string. Ctrl-C should do it IMHO.
Replies (1)
We announce version 5.0 rc1. In this major upgrade. we add more copy options. Ctrl+C will copy the raw string to the clipboard. Please download and give a try.
https://nosqlbooster.com/blog/announcing-nosqlbooster-50-rc/
Thanks for the replay, that's work.
However it would be helpful to have a hotkey for such operation in TableView mode (this also requires an ability to select a cell, not just a full row).
[off topic]
1. All bitmap icons/images do not have a proper resolution for HDPI monitors - so look ugly.
Screenshot: https://monosnap.com/file/XNQnIJed3Egai2QFVfw4jGll2hdh8d
(Windows 10, 4Kmonitor, 175% scale)
2. Tooltips are annoying. They are blink and hide data. Sometimes they are helpful, sometimes not. Consider to add an option for delay time and enable/disable with hotkey.
