Improper JSON Indentation in output panel
Dheemanth bhat shared this problem 7 years ago
Solved
Problem:
1917a238d2b147405af9eba426b4b9c1
Expected:
7a391c63861ebc386df0ad68fedbaf90
We have worked out a new build to resolve the issue, please download and give it a try.
Linux: https://nosqlbooster.com/s3/download/releasesv5/nosqlbooster4mongo-5.1.0.AppImage
Replies (1)
Thank you for your feedback. We will fix the issue in the next build.
Hey hi, How can I revert my Nosqlbooster to 5.0.2 (anything between 5.0 and 5.0.2 please) version?
Cant find download link for previous versions
Which edition are you using? If you are using trial or free edition, it always auto-update to the latest version by design. There is no option to turn the auto-update off. If you are using paid edition, please send me a mail with your reference number.
And, Why do you want to revert to previous version?
I am using 5.0.3 trial edition.
I want to revert to 5.0.2 because previous versions do not have the bug i reported (I am desperate about this fix is coz i deal with complex JSONs structures and i need it be indented properly.)
Thank you, this helped.
resolved in 5.1.0
