DBRef is missing $ref, $id, $db attributes
Pedro Cardoso shared this problem 8 years ago
Solved
Hello,
this my script in NoSQLBooster. See the result
However, this script works in the mongoDB enironment shell. Any ideia?
e6f1d863de8b06a9baee43576eda6f15
Heres the print of dbREF
/923fbcecfe65a781c22fd322454a5579
Replies (2)
Thank you for your bug report. We will fix the issue in the next build.
As a workaround solution, you can use DBRef.toJSON() to get "$ref","$id" and "$db" attributes.
var user=db.users.findOne({})
var dbRef=user.address.toJSON();
db[dbRef.$ref].find({"_id": dbRef.$id})
Fixed in 5.0.3
