Application crash if connection interrupted
Scott Colestock shared this problem 9 years ago
Cannot Reproduce
I'm noticing that every time the application has an issue with a connection being closed (like after laptop is suspended or network interrupted) that I get a popup dialog from Mongobooster followed by the application crashing/exiting. If you have unsaved work in your tabs, you will lose it. Would be great to keep things open and allow for reconnecting.
Replies (2)
Thank you for your feedback.I tried it a few times, but can't recall the issue.
1. Which version are you using? The latest version is 3.5.4, if you are using an older version, please update it first.
2. Which connection type? SSH or normal?
And, If possible, could you please give the detailed steps to recall it locally?
Thanks for your fast response. This is 3.5.4. I have a mix of SSH and normal connections. Please see this screenshot showing the error message that is shown right before the app shuts down: https://screencast.com/t/cwwPUn9sFTg
Repro steps are: 1) connect 2) put laptop to sleep 3) wake it up. This is on macOS.
I tried your steps with MacOS+SSH+MongoDB 3.4.2 Connection, but still can't recall the crash issue.
This happens with Mongo 2.6 clusters.
