AltGr + N should not be used for shortcut!
Tine Mlakar shared this problem 8 years ago
In Progress
On some keyboard layouts , AltGr+N is a way to write curly bracket ( } ). This shortcut is really pain in the a**, because it opens new window. Can you disable it (or make it possible for user to disable it).Thank you!
Replies (1)
I understand your needs, this involves a breaking change, and we will consider putting this change in the next major upgrade.
