Specifying Column Order when Exporting CSV
Randy AufDerHeide shared this question 4 years ago
Answered
When exporting data as csv, is it possible to specify the column order?
It would make our import/exports into Google Sheets a lot easier.
Replies (2)
There is a work-around solution. NoSQLBooster can export query results. You can add field selection(.project) and sorting methods(.sort) to the query. You can also use the one-click projecting and one-click sorting operation to generate related query code. Then export the query to a CSV file.
BTW, you can export the dataset to excel and then use excel for field selection and sorting.
408c9ccd9c3be0ed801f4e676e5a352c
For example:
db.unicorns
    .find({})
    .projection({  //select your columns
        loves: 1,
        weight: 1,
        gender: 1
    .sort({ //sorting
        weight: -1,
        gender: -1
    .limit(11)
Thank you for the feedback. I don't think this addresses my concern but it may be because I wasn't clear.
When I export data, I need the fields/columns to be in a specific "position".
For example, when I export, I may want:
Field 1: Weight
Field 2: Gender
Field 3: DOB
Field 4: Name
and just to be clear, lets say I want another saved query to have the columns export like this:
Field 1: DOB
Field 2: Weight
Field 3: Gender
Field 4: Name
** I know some people might say you should do this in another app but if its possible to do it when I export the data, it makes things a lot easier.
Is this possible?
You can adjust the order of field exports through the projection method, and you can save the query or save it as a read-only view for later use.
db.example
    .find({})
    .projection({
            Dob: 1,
            Weight: 1,
            Gender: 1,
      // .saveAsView("query_view")
