SQL does not produce what I want
Gus Tanudji shared this idea 2 months ago
Completed
I did this, which basically groups two different queries in brackets an AND operator:
SELECT * FROM Monthly_Merchant_Fees where (Year >= 2020 and Month >= 2) and (Year <= 2020 and Month <= 2)
But what I get is the following. Where are the brackets that I purposely add to groups two queries together?
db.Monthly_Merchant_Fees.find({
Year: {
$gte: 2019,
$lte: 2020
Month: {
$gte: 2,
$lte: 2
Comments (4)
Actually,
I managed to activate "Verbose Shell", and the result is really weird. As you can see below, it does not have any reference to the any part of "$gte" query.
mb.runSQLQuery(`
SELECT * FROM Monthly_Merchant_Fees where (Year >= 2019 and Month >= 3) and (Year <= 2020 and Month <= 2)
`).sort({_id:-1})
.limit(100)
to the translated code:
/6237a95c31e2cd2cbf2acc56c104fe32
We have worked out a new test build to resolve this "group and" issue, please download and give it a try.
MacOS: https://nosqlbooster.com/s3/download/releasesv5/nosqlbooster4mongo-5.2.11-beta.1.dmg
Windows: https://nosqlbooster.com/s3/download/releasesv5/nosqlbooster4mongo-5.2.11-beta.1.exe
2
Hi Qinghai,
I have installed the exe and it produces a different code now, which seems more correct.
However, I actually expect a different result as I explain below:
I have a collection, XYZ that contains:
Year Month Value
2019 1          AA
2019 2          AB
2020 1          A
2020 2          B
2020 3          C
What I want to do is something like this in SQL, which basically making two groups of "and" queries
SELECT * FROM XYZ WHERE (Year >= 2019 and Month >= 3) and (Year <= 2020 and Month <= 2)
I expect the result to be
- 2020 1 A
- 2020 2 B
There is something wrong with your query and the result is empty.
https://www.db-fiddle.com/f/fQEfNA9pnp8u6V1jME7xdG/0
Thanks qinghai. I think your fix is good anyway.
Resolved in 5.2.11
