Running statement at cursor and retaining previous result tab
Kundan Verma shared this idea 20 months ago
Under Consideration
It would be better if we can run statement at cursor position without selecting the statement and by pressing some key .
Also retaining previous result tab would be helpful.
Both the feature are available in Studio 3T.
Comments (1)
1. You can run the current statement by pressing "Command+F6".
2. About retaining previous result tab, thank you for your idea, we are going to study it thoroughly and decide on the best way of implementing it
