How to query boolean use SQL?
LeoCui shared this question 5 years ago
Answered
mb.runSQLQuery(`
SELECT * FROM daily where index = true;
`).sort({date:-1})
.limit(100)
OR:
SELECT * FROM daily where index is true;
col 'index' is boolean,but when execute it , return messge:
"message" : "SyntaxError: Line: 1 Column: 32, Expected [A-Za-z0-9_:] or [A-Za-z0-9_] but ' ' found.",
"stack" : "script:2:4",
"sql" : "SELECT * FROM daily where index is TRUE )",
"___" : " ^ ",
"location" : {
"start" : {
"offset" : 31,
"line" : 1,
"column" : 32
"end" : {
"offset" : 32,
"line" : 1,
"column" : 33
Replies (1)
Both of these methods are OK.
SELECT * FROM daily where index = TRUE
or
I noticed that there is an extra closing parenthesis in the SQL statement executed, which is not correct.
I can't reproduce the problem locally. Can you provide a complete reproduction step, including sample data and a complete script?
  1. NoSQLBooster Version e.g. 6.2.15
  2. Operating System e.g. macOS 10.13.6 / Windows 10 1803 / Ubuntu 18.04
  3. Expected Behavior
  4. Actual Behavior
  5. How to reproduce, include a sample JSON data and MongoDB script to reproduce the error quickly
  6. Screenshots
