using node modules
Dmitry D. shared this question 2 years ago
Answered
Hello.
Similarly this
npm install json2csv -g
and then in mongobooster
varjson2csv = require('json2csv');
I try to do
npm install request -g
var rq = require('request');
and get the error
"code": "MODULE_NOT_FOUND",
"message": "Cannot find module 'request'",
"stack": "script:1:10"
Please, help to solve this problem.
With best regards,
Dmitry.
Comments (3)
You don't need to install npm modules globally. You can install npm modules to your user data directory.
1. Main Menu -> Help -> Open User Data Directory
2. Righ-click menu: New Terminal at Folder https://tinyurl.com/kv9b5m2
3. run: > npm i request-promise ;//or request, you have to promisify it later.
  1. var rp = require('request-promise');
  2. await(rp('https://www.bing.com'))
4568e58b2a25be19a3b4fa97c1ddfe7e
Thank you very much!
Hello,
I've installed the timespan node module in my MongoBooster user data directory, and it seems to be installed.
  1. npm list
  2. +-- moment@2.18.1
  3. +-- node-fetch@1.6.3
  4. | +-- encoding@0.1.12
  5. | | `-- iconv-lite@0.4.17
  6. | `-- is-stream@1.1.0
  7. `-- timespan@2.3.0
However, when I try to use it in MongoBooster I get the following error:
"message" : "Cannot find module 'timespan'",
"stack" : "script:1:16",
"code" : "MODULE_NOT_FOUND"
Here's how I'm requiring the module:
  1. var timespan = require('timespan');
  2. var ts = new timespan.TimeSpan();
Any suggestions?
Thanks,
Jeff
There may be a problem with the node_modules path resolution.
Please open a terminal at MongoBooster user data directory, and run "npm init"
  1. > npm init -y
try it again.
It's working now. Thank you!!
Huh, this didn't work for me. I'm trying to perform an export (from the menu) of a query to a CSV file and the import of "fs" is not working:
"message" : "Cannot find module '/Users/craig-mbp/Library/Application Support/NoSQLBooster for MongoDB/node_modules/fs'",
"stack" : "script:2:1",
Here's what's installed:
NoSQLBooster for MongoDB$ npm list
mongobooster-user-module@0.1.0 /Users/craig-mbp/Library/Application Support/NoSQLBooster for MongoDB
├── chance@1.0.13
├── fs@0.0.1-security
├── long@3.2.0
├─┬ meteor-random@0.0.3
│ └── crypto@0.0.3
└─┬ mongodb@2.2.31
├── es6-promise@3.2.1
├─┬ mongodb-core@2.1.15
│ ├── bson@1.0.4
│ └─┬ require_optional@1.0.1
│ ├── resolve-from@2.0.0
│ └── semver@5.4.1
└─┬ readable-stream@2.2.7
├── buffer-shims@1.0.0
├── core-util-is@1.0.2
├── inherits@2.0.3
├── isarray@1.0.0
├── process-nextick-args@1.0.7
├─┬ string_decoder@1.0.3
│ └── safe-buffer@5.1.1
└── util-deprecate@1.0.2
I did a `npm init -y` to rebuild and still get the same error and restarted nosqlbooster and still doesn't work. Any ideas how to fix this?
Craig
2
I noticed that there is a "fs@0.0.1-security" module in your module list. It conflicts with the nosqlbooster's built-in fs module and you have to delete it and try again.
Yup, that fixed it. Thank you!!
Main Menu -> Help -> Open User Data Directory does nothing to me, not even print errors to console.
I'm running nosqlbooster Version 5.2.5 on Linux Mint 19.2
