SQL JOINS
Dinesh shared this question 2 months ago
Answered
I get Syntax error when I try to use JOIN -
select * from orders join inventory on orders._id = inventory.fields.orderid
The error seems to say that I can't use two periods on the tables, as in I can't use inventory.fields.orderid in the above example. Can you please clarify?
Comments (1)
Please double quotes the embedded field. inventory.fields.orderid -> "inventory.fields.orderid"
select * from orders join inventory on "orders._id" = "inventory.fields.orderid"
