nested $unwind not working while querying on MongoDB
Cannot Reproduce
Hi,
I have been trying to use the following query to unwind an array inside of an array to group certain attributes, the 2nd $unwind is not working.
The query is below:
db.ExecutionPlan.aggregate([
{$unwind: "$nodes"},
{$unwind: "$noses.mileStones"},
{$group:{_id:
{ "node_type":"$nodes.type",
"node_sequence":"$nodes.sequence",
"mileStone_seq":"$nodes.mileStones.sequence",
"mileStone_type" : "$nodes.mileStones.typeOfMileStone",
"mileStone_eventType" : "$nodes.mileStones.eventType"
Can you suggest if there is an issue in the query or if MongoDb does not support nested unwinds. Thanks.
The same problem
Also tried the following:
//{$unwind: "$noses.mileStones"},
{$group:{_id:
{ "houseBill":"$houseBill",
"containerNo":"$containerNo",
"mileStones":"$nodes.mileStones"
$unwind: "$mileStones"
$group:{_id:
"node_type":"$node_type",
"node_sequence":"$node_sequence",
"mileStone_seq":"$mileStones.sequence",
"mileStone_type":"$mileStones.typeOfMileStone",
"mileStone_eventType":"$mileStones.eventType"
Still not working.
{$group:{_id:
$group:{_id:
Still not working.
Thanks for opening your issue here! If you're reporting a bug, please make sure you include steps to reproduce it.
