Add Document, Edit Document, Remove Document, etc. pallet is not showing sometime
Cannot Reproduce
Pallet of Edit Document, Remove Document, etc. is not coming if we set view as a Table and run the query. if we change the view into Tree and back to Table, then the pallet is visible. Why we need to switch the view to show the pallet? How can I contribute to this project? is it open sourced? Thank you!
The same problem
NoSQLBooster is not an open-source project.
Thanks for opening your first issue here! If you're reporting a bug, please make sure you include steps to reproduce it.
