Kerberos Library is not installed
Robert Caplan shared this problem 7 years ago
Solved
I am getting the error below when attempting to create a connection with Kerberos authentication. This is occurring in version 3.5.2, please advise.
"cause" : {
"isOperational" : true,
"message" : "Kerberos library is not installed",
"stack" : "Error: Kerberos library is not installed" +
"at SSPI.auth (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\auth\\sspi.js:56:40)" +
"at authenticate (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\connection\\pool.js:186:17)" +
"at authenticateLiveConnections (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\connection\\pool.js:687:7)" +
"at C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\connection\\pool.js:726:5" +
"at waitForLogout (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\connection\\pool.js:717:33)" +
"at Pool.auth (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\connection\\pool.js:724:3)" +
"at Server.auth (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\topologies\\server.js:679:20)" +
"at Server.auth (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\qh-mongodb\\lib\\server.js:448:22)" +
"at authenticate (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\qh-mongodb\\lib\\db.js:1512:23)" +
"at Db.authenticate (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\qh-mongodb\\lib\\db.js:1561:44)" +
"at C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\qh-mongodb\\lib\\mongo_client.js:362:23" +
"at C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\qh-mongodb\\lib\\mongo_client.js:326:5" +
"at C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\qh-mongodb\\lib\\db.js:236:5" +
"at Server.connectHandler (C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\qh-mongodb\\lib\\server.js:339:7)" +
"at Server.g (events.js:286:16)" +
"at emitOne (events.js:96:13)" +
"at Server.emit (events.js:188:7)" +
"at C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\topologies\\server.js:298:14" +
"at C:\\Users\\caplr\\AppData\\Local\\mongobooster\\app-3.5.2\\resources\\app.asar\\node_modules\\mongodb-core\\lib\\connection\\pool.js:456:18" +
"at _combinedTickCallback (internal/process/next_tick.js:67:7)" +
"at process._tickCallback (internal/process/next_tick.js:98:9)"
"cause" : {
Replies (1)
Thank you for your feedback.
It is a bug. We have worked out a new build to fix it, please download and give it a try
https://s3.amazonaws.com/mongobooster/download/3.5/mongobooster-3.5.3.exe
